Engine and Transmission removal? >
Old 10-09-2002 | 08:39 PM
Default Engine and Transmission removal?
I am trying to remove my engine with the tranny attached and I am not having much luck my engine campartment is too small. I have Velvet trannys, does the tailstock or whatever you call it that bolts into the bottom half of a TRS transom plate come apart from the tranny or is this actually part of the transmission? I can see a gasket between the main body of the tranny and the part that bolts to the transom plate and it looks like it is supposed to come appart but I can not find any bolts on the back side, but it feels like there are round studs on the backside but no threads or nuts or boltheads If I can get this part off, my engines will come out easy.
THRILLSEEKER is offline
Old 10-09-2002 | 08:49 PM
David's Avatar
That is the tailstock and it does unbolt, but it's not recommended to disassemble. I ran into the same situation, where the engine/ trans was extremely tight. I had to rotate the engine towards the side, and remove the accessories from the front of the engine.
David is offline
Old 10-09-2002 | 09:59 PM
Can you remove the back seat that was the easy way to get the eng out of the formula that I used to have.
fstboater is offline
Old 10-10-2002 | 06:52 AM
David, Why is it not recomended to remove the tailstock? Also is it a Mercruiser part or a Borgwarner part. Do you know how the tailstock comes off, I belive that if I can get this off my engine and tranny will come out easy. Do you know where I can view pictures of this part unattached to the tranny? I cant find it on Mercury or the Marine Transmissions site
Old 10-10-2002 | 10:09 AM
Mbam's Avatar
Offshoreonly Advertiser
Aside from the mess, there is no reason you can't pull it. It is a Mercury part, see
Tailstock dwg on mercruiserparts.com for a drawing.
Mbam is offline
Old 10-10-2002 | 10:42 AM
Tailsock comes off, no problem. The bolts are on the back side and may be very difficult to reach between the tranny and transom plate. It will probably be a bigger pain to reassemble in the boat.
I would try to pull it with the engine.
Gary
Gary Anderson is offline
Old 10-11-2002 | 06:51 PM
FWK
I have the same set up as you but I have a lot of room. I would pull the whole thing and not take it apart. I would remooe all of the accessories and the crank shaft pulleys if possible andf maybe you will have enough room. It may be possible to unbolt the trans from the engine and side it free from the tranny also. Good luck Forrest
Old 10-11-2002 | 07:52 PM
rws's Avatar
rws
I have a 20' Cigarette /TRS my Engine compartment is very tight!I have to remove all components from the front of the engine,then remove motor mounts I then use a ratchet strap to hold the weight of the trans.Then unbolt engine from the trans, and pull it out .It pays to be able to tilt the engine at reassembly.
Rob
rws is offline
Sea Rat
Powerplay
5
12-07-2007 07:12 PM
Donman
11
10-13-2006 07:21 AM
robert johnson
3
01-21-2004 08:46 PM
Crazyhorse
08-19-2003 07:02 AM
THRILLSEEKER
6
10-07-2002 03:53 PM
