Lifter madness >
Lifter madness
Lifter madness
Old 03-26-2017 | 09:41 AM
  #51
I think on my next go-round, I'm moving to solid lifters . (on a solid cam).
Too many variances in hydraulics. Lifter type, oil viscosity, oil pressure, oil aeration, cam profile effects, oil temperature, spring pressures, and so on. At least with solids, you know what you got. Rules out alot of potential issues.
The big reason hydraulics were so popular, was the noise, and fact you don't have to adjust/check lash. Neither of those things are a big deal to me, but I can see where they may be to others. I am kinda wishing I had switched last winter when the engines were out. Because I could have took a look at lash right now, and get a decent idea how my new heads/valve seats and rest of things are holding up.
MILD THUNDER is offline
Old 03-26-2017 | 09:48 AM
  #52
Got into my Whipple 525 this week and fairly certain they're crane 13532-16 installed fwiw
[ATTACH=CONFIG]565860[/ATTACH]
IGetWet is offline
Old 03-26-2017 | 09:57 AM
  #53
I agree MT ^^^ that's what I'm trying next, then I will personally experience both and see.
It sounds like a lot of the negativity towards solids is exaggerated or not true, and the positives don't get brought up much.
They are not for everyone though.
offshorexcursion is offline
Old 03-26-2017 | 10:00 AM
  #54
FYI Jesel rockers and solid rollers are quiet
adk61 is offline
Old 03-26-2017 | 10:06 AM
  #55
vintage chromoly's Avatar
I have solid flat tappet EDM litters in my 440 Mopar engine. (.903 factory size on a Mopar) and they are really pretty quiet.
Lots of the rhetoric you hear / read in mags and on the net come from guys who have never used them.
I have morel solid rollers (.903 on a 55mm cam) in the BBC boat engine (dyno time only) and they are quiet as well. One thing I'll be watching is the long term durability of the solid roller.
vintage chromoly is offline
Old 03-26-2017 | 10:16 AM
  #56
Heck, theres a ton of guys who honestly, aren't getting much benefit from their "roller" cam setups. Some are running 800 dollar lifters, a 500 dollar billet cam, and aren't spinning more than 5400rpm, or making more than 500ish hp. Something that can easily be accomplished with a flat tappet, that costs 1/4 the price. A good setup with the groove cut or EDM oiling, proper springs, and a proven cam design, they can outlast the piston rings. Rollers are great, but they are fricken heavy too. Hence the need for lots of spring pressure compared to a flat tappet. I think theres many who would be better off sinking the money into better heads, better exhaust, or better induction, rather than into the big dollar lifters and cam core.
Old 03-26-2017 | 10:46 AM
  #57
they live if you're diligent in oil maintenance and keeping your engine idle time to a minimum... I usually run out of marinas and no wake zones on one engine flipping back and forth between both the two... I've been running the same Crower pressure fed solid rollers in the last 3 sets of engines... and I beat the dog sh*t outta my gear so FWIW yes solid rollers will be fine as long as your realize idling them is what kills them... FYI my spring pressure is 285 on seat 800 open
adk61 is offline
Old 12-03-2017 | 09:05 PM
  #58
would a tie bar lifter stand up better then a tall body dog bone style lifter?
looking at the GM 17120060 lifters - used in the 572/620 motor vs say the crane 13532-16 and wondering if their is any one that stands better?
575sci update motor, more boost and more cam
LTZCrew is offline
Old 12-03-2017 | 10:57 PM
  #59
put johnsons in and call it a day...
1MOSES1 is offline
Old 12-04-2017 | 09:40 AM
  #60
i recently used a set of the comp short travel hyd roller lifters on a n/a 509 build and i liked them.i won,t use the morel hyd roller lifters anymore,out of 10 sets i had 3 lifters colapse right away on the dyno,this was during warm up.i had to replace the bad one before a dyno pull could be made.i think comp cams hit a home run with their short travel hyd roller lifter.
mike tkach is offline
