-   -   Flare to AN adapter (https://www.offshoreonly.com/forums/general-q/345701-flare-adapter.html)
class6 03-28-2017 05:22 AM
That's it. Look at the o ring area. If you drill it out. It will take out the o ring
F-2 Speedy 03-28-2017 06:30 AM
Pretty sure their talking about drilling it out completely and tap to NPT and installing NPT to AN fitting
class6 03-28-2017 11:00 AM
Yes. I was about to do that. The way it is cast. You run the drill bit through. It will take out the o ring. I'm just going bore/drill it out just before the angle of the casting.
class6 03-28-2017 11:01 AM
I just got a call. The hydraulic shop I use found fittings.
F-2 Speedy 03-28-2017 11:10 AM
There's no O-ring on an inverted flare, or at least Ive not seen one
Cole2534 03-28-2017 11:18 AM
I think he means the filter gasket area.
Keith Atlanta 03-28-2017 11:19 AM
LOL, when I did mine I thought "I should take pictures and write this down somewhere, surely somebody will want to do this again..."
And the day has come.
And I didnt write it down or take pictures.
At least you figured it out!
SB 03-28-2017 11:29 AM
That's how I took it. But not 100% that's what he meant.
class6 03-28-2017 11:43 AM
That's what I meant. The filter adapter base o-ring gets in the way. If it wasn't. It would have been done.
SB 03-28-2017 11:56 AM
So, it looks if anyone wants a bigger line size they will have to get an aftermarket filter base.
