Cam Upgrade comparison.... >
Old 03-27-2017 | 05:13 PM
Trippin's Avatar
Default Cam Upgrade comparison....
Wondering if anyone has any first hand experience or knowledge of which cam application might better suit my build. Twin GEN VI 454 MAG/MPI's, keeping the fuel injection, not interested in going carburation.
The Teague BBC GEN V-VI Billet stage 1 : Advertised duration 288/296 .50degrees 226/234 LSA 112 587/610 Gross lift
Comp Cams BBC GEN VI HYD ROLL " " 283/290 .50degrees 223/230 LSA 114 566/575 Gross
Staying with the factory bore & stroke, factory forged internals all stock, doing a 3 angle valve job and matching springs for which ever cam I select, adding roller rockers. Re-plumbing the fuel system removing the VST and manual pump assembly adding full electric fuel systems with adjustable fuel pressure regulators and having the ecms reprogrammed for the new fuel and air flow upgrades
Any opinions?
Trippin is offline
Old 03-27-2017 | 05:23 PM
if your thinking of the teague cam,,just get the crane 731 20yr old tech cam that works.
sutphen 30 is offline
Old 03-27-2017 | 05:25 PM
I'd go option 1 but that's just me however a proven cam time and time again.
getrdunn is offline
Old 03-27-2017 | 05:27 PM
Aren't they pretty much the same?
I've never confirmed timing events btwn teagues version and 731 however I would imagine they are very simlilar. One nice thing with Teague is they would likely assist with fuel/ecm etc.
getrdunn is offline
Old 03-27-2017 | 05:57 PM
Basic Operating RPM Range: 1,600-5,600
Intake Duration at 050 inch Lift: 226
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 226 int./236 exh.
Advertised Intake Duration: 288
Advertised Exhaust Duration: 298
Advertised Duration: 288 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.587 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.610 in.
Valve Lift with Factory Rocker Arm Ratio: 0.587 int./0.610 exh
Lobe Separation (degrees): 112
phragle is offline
Old 03-27-2017 | 06:35 PM
the teague cam is a crane 168731 cam.
mike tkach is offline
Old 03-27-2017 | 06:49 PM
SB
The answer will be given by whomever is doing your computer programming.
SB is offline
Old 03-27-2017 | 07:01 PM
PN: TCM STG1GVI
BBC GEN V-VI BILLET CAMSHAFT - STAGE 1
Google Plus Facebook Twitter
Email to a Friend
Be the first to review this product
Availability: In stock
$441.00 ADD TO WISHLIST ADD TO COMPARE
QTY:
Add to Cart
Quick Overview
TCM Camshaft: STAGE 1, GEN VI, HYDRAULIC ROLLER
Operating Range: 2500-6000 RPM
Duration Advertised: 288° Intake / 296° Exhaust
Duration @ .050'' Lift: 226° Intake / 234° Exhaust
Gross Valve Lift: .587 Intake / .610 Exhaust
Lobe Separation Angle: 112°
BBC Gen V-VI Billet Camshaft - Stage 1
Two deg less exhaust duration yet Teague advertises 2,500-6,000 WHAT???
getrdunn is offline
Old 03-27-2017 | 07:22 PM
What exhaust are you using?
MILD THUNDER is offline
Old 03-27-2017 | 07:59 PM
[QUOTE=Trippin;4541264]Wondering if anyone has any first hand experience or knowledge of which cam application might better suit my build. Twin GEN VI 454 MAG/MPI's, keeping the fuel injection, not interested in going carburation.
And you do what for a living? Boat mechanic?
GETTINBYE is offline
