Cutler isn't the only one. I've had a few like that. Not quite as bad.
A Nylatron washer might be easier to work with ......if you can find one 2 mm thick just use it as your gasket after you grind off one side .
That sucks on the alignment |
looks like somebody machined the dist hole deeper. check to see if dist body seats to manifold or if it is being held up by oil pump drive.
Originally Posted by midwest272
(Post 4542443)
Originally Posted by dereknkathy
(Post 4542943)
I'd LIKE to replace it with a slip collar distributor but not finding much luck finding one that will work.. Has to be marine certified. Slip collar HAS to be a ready to run.. My efi doesn't have a "mag" input Locked out timing. Re-phasable rotor. (my Thunderbolt rotor is phased just the the Crane hi6m was) |
Can you find somebody with a lathe and machine off the lip on the dist. and just add a slip collar to your distributor?
Originally Posted by fbc25el
(Post 4542985)
I'm not sure.. Problem I see is it's a cast aluminum distributor and not round above the flange... http://i130.photobucket.com/albums/p...psqcppkpee.jpg I DO have a "tall deck" version of a Thunderbolt, designed to be used with a tall deck block and a standard intake manifold using spacers.. It's about an inch TOO tall.. may be able to figure out a slip collar for that one... http://i.ebayimg.com/images/g/xBwAAO...~Y/s-l1600.jpg |
Just curious, did you happen to remove the throttle body and look down the runners with a light to see how things are lined up ? And do you see any wear marks on the bottom of the distributor gear where it's rubbing on the block ?
Originally Posted by GPM
(Post 4543006)
Looks like voice to text. Long gate I figured out. What is a China wall?
That dust hole in intake is WAY too big. It is supposed to be a loose clearance fit on distributor body. That is close to half inch bigger than dist. Dist can flop all over in there. GET A NEW INTAKE!! Somebody butchered that dist hole. I was thinking mebbe a bushing to correct suze, but they could cut it out off-center...
| All times are GMT -5. The time now is 03:46 AM. |
