Oil leak at distributor.
I'd LIKE to replace it with a slip collar distributor but not finding much luck finding one that will work..
Has to be marine certified.
Slip collar
HAS to be a ready to run.. My efi doesn't have a "mag" input
Locked out timing.
Re-phasable rotor. (my Thunderbolt rotor is phased just the the Crane hi6m was)
I'm not sure.. Problem I see is it's a cast aluminum distributor and not round above the flange...
I DO have a "tall deck" version of a Thunderbolt, designed to be used with a tall deck block and a standard intake manifold using spacers..
It's about an inch TOO tall.. may be able to figure out a slip collar for that one...
Just curious, did you happen to remove the throttle body and look down the runners with a light to see how things are lined up ? And do you see any wear marks on the bottom of the distributor gear where it's rubbing on the block ?
This would be the first thing I would do. If they are off front to back you could long gate the holes. How does it sit on the china walls?
That dust hole in intake is WAY too big. It is supposed to be a loose clearance fit on distributor body. That is close to half inch bigger than dist. Dist can flop all over in there. GET A NEW INTAKE!! Somebody butchered that dist hole. I was thinking mebbe a bushing to correct suze, but they could cut it out off-center...
