AC Units - installed
Exactly what I did also.
they come with a thick mounting pad, never used more than that, did some performance boat installs and never had a failure
Hey Penis, check mcmaster carhart, they have some cool spring loaded isolation mounts
the main thing had had to deal with on performance boat apps is the water pickup, most do not want to add a scouped thruhull(understandably) without this style will loose prime to pump when you run, so you have to bleed everytime you use, can be a pain we set up with a bleed valve now and makes it easy
