Where should the oil filter be located? >
Old 04-23-2017 | 08:23 PM
Default Where should the oil filter be located?
I'm replumbing my oil sustem to include a thermostat and it got me to wondering.
Anyone have pics of the best place to locate an oil filter head?
Cole2534 is offline
Old 04-23-2017 | 10:25 PM
Quick Overview
HP6A Head mount & filter,Our Billet HP6A remote filter head mount is CNC machined from 6061-T6 Aluminum with large 3/4" NPT oil ports in/out and four 1/8" NPT ports for any oil pressure senders and/or switches. Supplied with a 1 1/2"/-12 threaded adapter to fit Fram HP6A or equivalent filter. TCM filter mounts enable easy filter access with supreme filtration and maximum flow. Also available with the smaller HP4 filter assembly.
Rotating billet filter head for easy installation. Made in the U.S.A.HP6 20 microns @ 20 GPM 6.12" (H) X 4.50" (OD)
*Color
-- Please Select --BlackBluePewterPolishedPurpleRed
* Required Fields
$179.97 Qty: Add to Cart .Add to Wishlist| Add to Compare.BBC Cylinder Head Mount (HP6A)
at Teague Custom Marine
I'CE is offline
Old 04-23-2017 | 10:38 PM
It can be mounted anywhere you want. On my 24 Outlaw, I made a bracket and mounted it to the transom.
Griff is offline
Old 04-24-2017 | 08:47 AM
I am doing the same thing and ended up getting one of those billet brackets with the Hardin remote filter.
Tahoe540 is offline
Old 04-25-2017 | 05:11 PM
Does anyone prefer it to be mounted threads up or down?
Cole2534 is offline
