bilge pump replacement advice
It's a certain type (model) that does cycle. Every to minutes it energies for a few seconds. If it feels resistance from water, it keeps going, if not it shuts right back off. It's for applications here there isn't a good place o put a float or for people that don't want to deal with a float.
Sorry about above.
Okay, here: The 'S' models
AUTOMATIC SUMP PUMPS
Rule Pumps 12 Volt DC Automatic Bilge Pumps 500 GPH - 2000 GPH feature computerized operation on the principle of impeller resistance. Float switches are not required. The pump will turn on every 2-1/2 minutes to sense for water. If water is present, the pump will sense resistance
and continue to run until all the water is removed. Thereafter, it will check for water every 2-1/2 minutes.Power use in the checking mode is minimal.
Ships next business day
Rule Pumps 12 Volt DC Automatic Submersible Pump Data
Model GPH Amps @12v Amps @13.6v Fuse Size Height Width Weight (lbs) Hose Diameter
25S 500 1.9 2.5 2.5 4” 2-3/8” 1 3/4”
27S 1100 3.3 5.0 6 4-1/2” 2-3/8” 1 1-1/8”
53S 2000 8.4 12.0 15 7-3/4" 4-3/4” 4 1-1/8”
I'm the same. Boat I had did the cycle every 2 minutes thing. Drove me nuts. I keep boat on the trailer. Hanging out on home on the deck, you'd hear the buz every two minutes. Doing something outside, buzz...silence...buzz. Last straw was when I was cleaning outside of boat, pump cycled while I walked by it, got a quick squirt of bilge water on me,was not enough water in bilge to trigger a float.
Gone !
Gone !
For the OP, if you have a hard time getting to pumps with the engines in, install back-ups now.
When I had my last boat ('02 35) at Eddie Young's shop, I had him install 2 new pumps. Originals worked fine, but they were 13 years old. Time for new while in there. I believe he installed Johnson Automatic's like these....
https://www.westmarine.com/buy/johns...ps--P011006897
Cheap insurance if engines are out.
