bilge pump replacement advice >
Old 04-24-2017 | 08:23 PM
Default bilge pump replacement advice
I have both Motors out of my 32 fountain fever and trying to decide what to do as far as bilge pumps if I should replace the originals or leave them be as they seem to work fine (in that case they'll fail the first time out this year). I dont really like the new rule's that cycle on every 2 minutes as the boat sits in my shop year round with the batteries on and they don't need to run all the time.
T_traylor1 is offline
Old 04-25-2017 | 05:47 AM
jeff32's Avatar
In a 32 i would change the pump! No room to do it later with engine in if my memory serves me right!!!
jeff32 is offline
Old 04-25-2017 | 07:59 AM
32s have been known to take water through the back vents and sink at the dock, motors are out...go new. I was unaware of new rules requiring them to cycle every 2 minutes...is that true?
JRider is offline
Old 04-25-2017 | 09:08 AM
SB
^^^Just a certain model. They usually don't have float switches/^^^
SB is online now
Old 04-25-2017 | 09:40 AM
When I had my last boat ('02 35) at Eddie Young's shop, I had him install 2 new pumps. Originals worked fine, but they were 13 years old. Time for new while in there. I believe he installed Johnson Automatic's like these....
https://www.westmarine.com/buy/johns...ps--P011006897
Cheap insurance if engines are out.
ALL_IN! is offline
Old 04-25-2017 | 11:10 AM
Definitely change the pumps. I went with Rule 2000 pumps and float switches about two years ago.
HyFive578 is offline
Old 04-25-2017 | 11:54 AM
I went with rule2000s with my motors out. They are internal sensing.
Crude Intentions is offline
Old 04-25-2017 | 12:10 PM
I don't mind float switches I just don't see the need for them to cycle all the time. Guess I'll do a set with external floats
Old 04-25-2017 | 12:21 PM
Mine didn't cycle. Not sure I've seen ones that do.
ALL_IN! is offline
Old 04-25-2017 | 12:26 PM
SB
I'm the same. Boat I had did the cycle every 2 minutes thing. Drove me nuts. I keep boat on the trailer. Hanging out on home on the deck, you'd hear the buz every two minutes. Doing something outside, buzz...silence...buzz. Last straw was when I was cleaning outside of boat, pump cycled while I walked by it, got a quick squirt of bilge water on me,was not enough water in bilge to trigger a float.
Gone !
SB is online now
