lineup ssm3 and engines
the bar is the same but the puck that goes into the helmet is smaller on a SSM drive... just went thru this on the weekend with another buddy up here... he bought a TRS alignment tool thinking they're the same, and found that the locator puck doesn't go into the recv'r register in the helmet!!
I just went to look in my merc service manual, it shows the same tool part number , for TRS, SSM II,III,IV,V, VI.
On the one i have, the puck/disc thingy, has one step to it.
If anyone knows of different puck part numbers , id be interested in seeing them.
Last year, i had some O-rings new in a package. The ones that go on the drive around the driveshaft housing bore, where it seals to the bellhousing. I installed them on the drive, then slid the drive on. Something didnt look right. The o ring was really thick. I had assumed they were for the ssm setup. Turned out, they were for a trs setup, must have ordered them years ago and never used them. Anyhow, ordered up the ssm ones, and when they came, they were the same diameter as the trs ones, but thinner.
Mild Thunder, you write I can Mount trannie on inner transom? the one i have is suppose to sit on engine and have a big rubber seal going into inner transom? Am i missing something..its a bam tranny
