fuel pump
I have a 1999 502 MPI my fuel pump went bad. I bought a after market electric pump using the OEM number, the push on fitting is very loose used OEM number when ordering parts is there a fix for this Mercury no longer has this pump.
Did you replace the 4 o-rings (2 on each side of the push in 90* fitting between pump and fuel cooler ?
I think Merc still sells the pump and cooler as a kit together.
Rumor has it that Merc's OE pump is Airtex also...if that's the brand you got as aftermarket ?
Edit in: Don't forget to use a good heat transfer paste between pump and mounting plate....don't use any clear dielectric grease most manufacturer's/ part stores try to pawn off as heat transfer paste. Dielectric grease is clear - most good heat transfer paste's are white, but never clear.
Yes I replaced all 4 o rings on the push in 90. If Mercury sells a pump and cooler as a kit I can not find a part number. No, I do not know which pump I got, it was a no name pump got from Mr. Fuel Pump. Got the o rings from Bam Marine in a clear bag wondering if they are right size I matched the two up they same.
If you bought this one then it should be the correct
http://www.ebay.com/itm/861156A1-861...item25ca7a8894
As to why its feels loose is unknown to me
