4 and 7 swap >
4 and 7 swap
4 and 7 swap
Old 05-09-2017 | 11:44 AM
hammerdown500's Avatar
Default 4 and 7 swap
I have a 525 cam in my 502 and I am.having ignition timing issues does anyone know if the the stock 525 efi has the 4 and 7 plug swap
hammerdown500 is offline
Old 05-09-2017 | 12:02 PM
F-2 Speedy's Avatar
it does not, standard firing order
F-2 Speedy is offline
Old 05-09-2017 | 12:24 PM
Old 05-09-2017 | 01:58 PM
SB
You can get the 525EFI CAM from Crane with the 4/7 swap. Do you have paperwork for your cam ? Or did you get it used ?
SB is offline
Old 05-10-2017 | 04:30 AM
it would be a dead miss on 4 and 7 if it was a swapped cam. running on 6 cyls.
dereknkathy is offline
Old 05-10-2017 | 09:58 AM
Sorry for the side track, but any real benefit to this swap? Would it at least sound cooler?
Baja Rooster is offline
Old 05-10-2017 | 10:28 AM
The real Advantage is five and seven aren't firing one after the other in the same exhaust manifold with the ports right essentially next to each other. But it's not a huge advantage. Some people like the way it sounds better with the 4-7 swap.
Old 05-10-2017 | 11:35 AM
http://www.hotrod.com/articles/lunati-cams/.
30ftpanther is offline
