Highest OIl Temps that are safe
#51
#52
Starting to think I have a ticking time bomb. Have a high volume oil pump so that's good with the HP I'm producing, but if I continue to develop 80 PSI oil pressure running hard, I'm going to spin a bearing or blow the oil filter apart. From what I understand is to use a high volume pump you need to increase the bearing clearance and if the was not done then I have an issue.
#56
Its hard to see,but is there a bypass valve in the oil in passage of the oil filter pad?if so,need to remove it.
The motor was first tuned with a different prop set on then what I have now. Do agree, if its off the heat will increase, and plan to have the AFR checked soon. As before I'm glad I installed a temp gauge, because the water temp gives no indication of an issue.
#58
Had a short couple runs today and no WOT, just cruised at 3600 rpm, using 20W50 Castor Oil. Motor stayed at 160 degrees for max temp both runs
Cold start about 60 psi, idle out thru no wake, motor at almost 140 degrees, throttle up, seeing 75 psi and temp came up after 7 mile run to 220 degrees.
Back in, temp at 110 degrees, throttle up and see 78-80 psi, temp comes back up after a bit to 220 degrees.
Idles hot both times after runs around 40 maybe a tad above.
My filter is still leaking a slight bit of oil (2nd one). Do I crank it down tighter or something else?
#59
If your filter is leaking, check the surface on the remote mount. make sure its flat and smooth. You only need to tighten the filter as normal. I have never had an oil filter ever leak around the gasket.no matter the pressure.
