525 EFI circulating pump >
Old 05-31-2017 | 09:05 AM
Default 525 EFI circulating pump
Hi,
I was wondering if anyone has successfully used an alternative circulating pump on the 525 EFI motor? The factory part number is 811573A04 available for around $400. There are several pumps available that cross-over to the 811573 pump, but those were primarily used on the earlier non-closed cooled motors. Thanx!
509 SC is offline
Old 05-31-2017 | 09:09 AM
i am going to try that on a pair of 500 efi engines i rebuilt because the owner did not want to spend the money for the correct pumps,i hope they work.
mike tkach is offline
Old 05-31-2017 | 10:08 AM
BUP
I will check later for you guys I possible have them in stock for 195 each shipped to your door. I have all my water circ pumps made here in the USA. For all Marine engines including the LS and a few Ford marine versions as well.. Mercruiser last year started using the exact place as to where I get my pumps made. These are all marine rated water circ pumps. I have to check and see what I have left currently. THANKS
BUP is offline
Old 02-28-2021 | 05:11 PM
Dean Ferry's Avatar
Yeah I'm going to try the 811573 for 1 of my HP500 EFI's instead of the 811573A04... Port engine is intermittently weeping a little water out the shaft, just running on the hose..
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 03-01-2021 | 08:58 AM
Dean Ferry's Avatar
I went with this pump:
Mercruiser Water Pump→circulating water pump→GM Big Block V8 (ebasicpower.com)
Old 03-07-2021 | 08:32 AM
Dean Ferry's Avatar
Well, I got my Recir pump from Basic Power and got installed and it works like a Merc Racing $400.00+ Recir pump!
I was a little concerned when I laid them side by side, and on the Basic Power pump, the inlet snout was a little longer, (Red arrow points to Merc pump), but it installed, no problems... $109 vs $403......
Old 03-07-2021 | 04:15 PM
I just bought 3 of these exact pumps for my fresh motors. Get to run them in the gulf hopefully this week. I only have 502's but they matched up perfectly. We shall see. 😁
smashm is offline
Old 03-08-2021 | 09:40 AM
Dean Ferry's Avatar
Yeah I hope to get home in time to splash the skater this weekend also. Weather supposed to be awesome in the low eighties
