HP 500 carb electrical  and temp issues >
Old 06-18-2017 | 10:27 PM
Exclamation HP 500 carb electrical and temp issues
What causes an alarm to sound sound on a marine engine, all gauges read normal but alarm is sounding,
419craig is offline
Old 06-19-2017 | 01:30 AM
For the alarm, there are only 3 things with senders that will set the alarm off. High Water temp, Low Oil pressure and Low drive lube. Disconnect each sensor one at a time when the alarm is sounding. The alarm sensors use a tan wire with blue stripe. If the alarm does not stop sounding when one of the sensors is unplugged, then the tan/blue wire has a short somewhere and is grounding out.
Griff is offline
