Mufflers with dry exhaust?
When i started using my dyno i had giant semi or tractor mufflers, i found they still cost 15 to 20 hp though, it may have been exhaust reversion though where 6" tube slipped over 5" tube. I had a set of 5" 400$ gibson clampons laying around and stuck them on the 5" pipes, they cost about 3 hp at 550 hp, cost 7 to 10 at 700 hp. After 100 pulls they still look fine and there is nothing in thembto burn out, might be a viable, cheap option for you! How much hp we talking?
I actually like the GGB idea. I have some extra polished 4" stainless pipe laying around that I could fab up some clamp on mufflers with those inserts. I'll have to check on them, but I am not going to get too crazy with it cause like I said, my home lake (Lake Cumberland) doesn't have any sound laws, I was just looking to take the edge off the exhaust sound. I have also bought some new exhaust manifolds and will be fabricating a whole new exhaust system that will have a pair of those mufflers that look like snails and whistle, but those won't go on for at least a year.
Thanks Guys!!
I have never heard the term 'snails and whistle.' Maybe it's my isolated part of the country.
Are you talking the auger (screw) type ? These typically cost power. My mild SBC loses almost 3mph with them installed. So say, almost 30hp.
That would be correct. I didn't realize there were o- rings, etc.inside. Heat would definitely toast the rubber. I was thinking more along the line of the Gibson exhaust that somebody else also mentioned. There is nothing inside those to burn. But, again without the water to cool them (water also does help with the sound!) they will get pretty ugly probably after the first run. As fas as the GGB's are concerned. I'm sure they are effective. Personally they scare me. Many years ago I had a dirt bike with the same set up in the exhaust. Now I understand the oil mixed in the gas makes the exhaust a lot dirtier, I get it. However, I had to clean them after every run or the holes gummed up and I lost power. Cleaning them was very time consuming and a complete pain. I tossed them. Probably wouldn't happen in this application, but they are not for me!
^^^^^^LOVE^^^^^^^^ Carry on!
I agree either the Gibson inserts or the Bullet Mufflers would be your best option being full dry, the Inserts being the option that wouldn't look like crap over time. Should slide right up the tails unless they aren't a straight shot out the transom and maintain the cleanest look. Would most likely help with reversion potential to dampen the exhaust pulses a bit too. That LS firing order tends to make reversion worse, ask me how I know! Haha.
