502 help!
Not sure I understand what the motor did as for idle but the not starting could be from a vapor lock. If you run out of gas and hold the throttle wide open the ECM thinks it's flooded so you get NO fuel. You have to just crack the throttle like half way and then it will get more fuel. Maybe you tried this I don't know.
