Blower with Carb questions >
Old 07-11-2017 | 09:46 PM
Originally Posted by TruxtonFox
2 1/4 turns out, idles perfectly, will run up to 4000 with no load no issues, soon as you put load on it she floods
makes me wonder if the ignition is up to snuff.
mike tkach is offline
Old 07-11-2017 | 09:51 PM
Good point
getrdunn is offline
Old 07-12-2017 | 06:42 AM
As far as the ignition goes it's the factory mercury ignition, new plugs and wires, set baseline at 13
TruxtonFox is offline
Old 07-12-2017 | 06:43 AM
Originally Posted by getrdunn
What 10-71's you have and how fresh are they? Just curious. I would have your carbs looked at and gone through by speed shop per your application. You decide to downsize to fresh tbs 8-71's let me know. Regardless what way your u go I'd definitely have a good trustworthy carb guy check your carbs out.
they are mooneyham blowers with mooneyham intercoolers, intakes and carb adaptors
Old 07-12-2017 | 07:30 AM
at this point i think you need to have someone with blower motor experiance take a look at it,it is tough to figure out what is going on without seeing it.
Old 07-12-2017 | 07:54 AM
Agreed, blew a driveshaft end up and getting another one today. Will test this afternoon/tomorrow and report back
Old 07-12-2017 | 08:43 AM
where's the fuel pressure at when flooding ?
ezstriper is offline
Old 07-12-2017 | 08:51 AM
Stays steady between 5-7
Old 07-13-2017 | 02:54 PM
I do not see a way it could be flooding at that RPM and fuel pressure and be fine at idle, something is scewy here...think you better have someone with blower motor experiance ride with you...
Old 07-13-2017 | 02:57 PM
Originally Posted by GPM
Just curious, and have no clue, would that motor ever see vacuum with a Roots style blower
yes, blower will create plenty of vacuum to carb
