My thought, mind you I don't know jack about carbs, but under load, doesn't the blower start producing boost at 3k? If it does, is the air coming through the carb being sucked harder and thereby letting the power valve open and dump to much fuel? A PV with a greater opening pressure would delay the onset of fuel until the higher rpm ranges.......spitballing
Originally Posted by TruxtonFox
(Post 4568759)
Typically, at 3000 rpm, in a 30ft boat, I would not expect it to be making boost yet. Irregardless, when the carb is NON boost referenced , the power valve is only seeing vacuum, and never boost. With a 4.5" PV, it will not open, until the vacuum drops below 4.5 inches. Going to a 10.5, will make it open sooner, and a 2.5, open later. On a typical 750 carb, the power valve channels are not huge, like say, a dominator . Even if it was in fact opening too early, it should not be injecting enough fuel to "flood" the engine. If your carb was "boost referenced", it likely would be opening at 3k rpm on plane. Reason being, I doubt you would be seeing 5-6+ inches of vacuum there. installing a wideband setup, would enlighten things. |
(Post 4568293)
Sorry guys, wasn't getting any email alerts. For sure flooding out, set needle and seats with boat at rest in the water. 100% sure it's flooding, plugs are wet. As I accelerate to get onto plane and hold at 3k the boat runs there for 10secs or so, slowly lose rpm and then motor does. Blowers are obviously way to big for the 502's, my thought was the blower was pulling the pPV's open to soon and flooding it out.
If your plugs are legit wet with fuel , after a 10 second 3k rpm run, I'm thinking you have a fuel delivery issue. Lets say, you have a cheapy fuel psi gauge. It shows 7psi, but there is actually 8 or 9 psi in the setup (seen them off many times). Maybe it will idle just fine with boat at rest, and not blow the needle off its seat. Now, you get on plane, and the float becomes very sensitive, and the addtl fuel psi , simply will not regulate the fuel entering the bowl like it should. Your typical holley float, does not play well with excessive fuel pressure. What kind of fuel pressure gauge are you using to set fuel psi ? What regulator are you using? I've seen guys fight issues like this, when using cheap dead head style regulators with elec pumps. Fuel psi varying all over, flooding out, etc. |
Originally Posted by MILD THUNDER
(Post 4568816)
Blowers really arent "wayy to big" for 502's. The 10-71 is not crazy bigger than an 871. Im running 420 B&M blowers on 468ci engines, which are close to an 871 in size. The engines run fantastic, and makes plenty of power.
(Post 4568822)
Were talkin about a 1071 on a basic stock 502 mag mpi long block with stock exhaust, you dont think it to big ?? Im learning the blower side of things and I know you, ICDP and Mike and others have a bunch on seat time with them.
Certainly nothing that is gonna cause plugs to get soaked in raw gasoline. |
(Post 4568839)
Some have ditched the 256 blower on the 575sci, for an 871, and saw some nice speed gains. The biggest issue with too large of a blower, is inefficiency due to leakage between the rotors, at low speeds. Unless hes running it at 30% underdrive, i dont see an issue. Heck, some guys run 871s on small block chevys.
Certainly nothing that is gonna cause plugs to get soaked in raw gasoline. Now, take a 177 blower, at 2:1, and install an 871, you may go from 11,000rpm rotor speed, to maybe 5000rpm rotor speed. Now theres something worth talking about |
Off topic kinda, but since we are talking blowers and boost.
Buddy of mine bought a boat with blown 572s. 1071s, dart 345s, chillers, etc. Engine expired within a few hours of ownership. Cams it had were way small for a 572, duration wise, in my opinion. Hyd roller. They made 883hp with 10psi before he took delivery of boat. Rebuilt engines over winter. Compression was lowered from 8.5:1 to 8:1. New cams i picked for him from the lunati catalog. Very mild 629 lift . Redynoed. Engines made 1000hp with 10psi, 950ish ft lbs. Stump pullers as it had over 900ft lbs from 4000 and up. Anyhow, in regards to the blowers. With the old pulley combo that made 10psi , and 883hp , now made 8psi, and over 900hp. He dropped 2psi, but gained power. Overdriving back up to 10psi, and then crested 1000hp. The orignal cam was choking it. So boost is not just relative to cubic inch, as we know |
it,s all about cylinder pressure,to little and power will be down,to much and detonation will kill the engine in short order.small cam&10 lbs boost won,t last long even with lower compression ratio.
for me if i have to choose between a blower that is to small or one that is to big i,l take the bigger one any day of the week,just spin it a little slower.
Originally Posted by mike tkach
(Post 4568849)
| All times are GMT -5. The time now is 04:41 AM. |
