496ho overheating? Or temp gauge not working right? >
Old 07-13-2017 | 11:02 PM
Doesn't matter garden hose or lake. As I put my hand on all the primaries coming from the block the only hot one was port side closest to front of engine
Snobo4rder08 is offline
Old 07-13-2017 | 11:13 PM
Check oil cooler water side for blockage.
underpsi68 is offline
Old 07-14-2017 | 10:24 AM
Plum_Crazy's Avatar
Correct.
This is what I found in mine. The boat didn't have strainers.
Plum_Crazy is offline
Old 07-14-2017 | 11:48 AM
Wow that is a ton of debris. What side is the water side? And does it come apart like the heat exchanger does on each end?
Old 07-14-2017 | 06:03 PM
Seawater flows thru the cooler. Inside is a honey comb looking series of tubes. Oil flows around these tubes cooled by the water flowing thru on the outside. These small hole opening tubes can become blocked/clogged by debris and become a restriction. No endcaps. Loosen breeze band clamps and remove rubber water hose to access seawater side.
Ryan00TJ is offline
Old 07-28-2017 | 10:29 AM
I am very interested in if anyone knows why my port side header gets super hot and my starboard is cool to the touch. Water does come out of both of tHem.
they are the cmi headers
This is due to the routing of the water from the big heat exchanger. When you take the endcaps off, looking at the water flow path, Water from the sea pump comes in the port side, flows across the HX makes a turn and goes back across, before it makes the turn, water flows to the starboard header. So your starboard header gets more cool water than the port side. I am still trying to figure out ho to balance the temps out myself. Most would probably say not to worry about it, but I just don't like it.
uncool is offline
Old 07-28-2017 | 01:55 PM
Originally Posted by Plum_Crazy
Correct.
Good beer there ^^^ .
92nsx is offline
