Bellhousing or O ring ? >
Old 07-20-2017 | 05:12 PM
Default Bellhousing or O ring ?
Ok i did this to myself, i pulled the out drive and i had to use a Screwdriver to get it to come off because i for got to get the last bolt at the bottom off. TOTALLY MY FAULT ...
i take it to the in house guys and they say $2000 and that i need a new Bell housing.
so i am going to try and include a picture here. ... OK i cant figure it out.. but the O ring on the Bell housing is visibilty bad i got the Kit for $8 ?
Thanks for all the help over the 20 years.
RUDY
powerqrudy is offline
Old 07-20-2017 | 06:12 PM
I'm in the dark but going to need something a bit more to even try to see what your talking about. With O rings I think this is a Bravo, don't know for sure
AllDodge is offline
Old 07-20-2017 | 07:10 PM
Yes i am sorry it is a 1993 Bravo 1 on a Powerquest
Old 07-20-2017 | 07:19 PM
Bravo is good but guess were really going to need the pic. The O ring kit as you know is cheap so need to know what is going to cost 2K
AllDodge is offline
Old 07-20-2017 | 07:53 PM
i can E mail it to you ?
Old 07-20-2017 | 07:56 PM
Send to [email protected]
AllDodge is offline
Old 07-20-2017 | 07:59 PM
They say the part of the Bell housing that the I ring goes into is a little out of shape and it needs a new Bell Housing.
Old 07-20-2017 | 08:04 PM
Can see how the ring may deform, but don't see how the bell housing will deform
AllDodge is offline
Old 07-20-2017 | 08:08 PM
Yea i am thinking of trying to clean the O Ring base up and put a new one in there?
Yea they say i need a new one.?
thanks for your help
Old 07-20-2017 | 08:20 PM
You need a new male fitting on the bell housing but not a new housing. The two pics you sent show the drive is OK other then the dent on the female part of the lube fitting. Part of the male part is broken off, so it is the only item that needs replaced.
The way I see it you only need item 24 the valve 18920A1
Genuine Mercury & Mercruiser parts. BELL HOUSING
Attached Thumbnails Bellhousing or O ring ?-slide1.jpg   Bellhousing or O ring ?-slide2.jpg   Bellhousing or O ring ?-g1.jpg
AllDodge is offline
