Daytona Sensors starter issues >
Old 07-25-2017 | 07:45 AM
Originally Posted by fbc25el
Make sure you read up on the rotor phasing and set it.
thanks maybe that's the issue
Cary 29 is offline
Old 07-25-2017 | 08:03 AM
Originally Posted by Cary 29
I'm running the na motor timing curve 34 deg all in.no.7 code I believe
You shouldnt have any start retard with that curve. You can enable start retard with a custom timing map.
What kind of cranking psi do you have when doing a compression test ?
MILD THUNDER is offline
Old 07-25-2017 | 08:16 AM
SB
Originally Posted by SB
+ how long have you had this system up and running , or new install ?
Originally Posted by Young Performance
Is this a new install? Did you modify your rotor or get the correctly phased rotor?
Eddie
Exactly what I was going to get to depending on his answer. Good to see I was thinking along the lines of others.
To the OP: The rotor is phased different from how the OEM rotor comes new. You can either do the modification yourself (Daytona has instructions for this) or you can simply by a modified rotor from them.
​​​​​​​Did you buy one from them already modded ? Did you do it yourself ? Or did you not know this ?
SB is offline
Old 07-25-2017 | 12:10 PM
You know we're a Daytona Sensor Dealer and we use their products daily but we dyno every engine we build so it's a fool proof system you may want to give them a call about the proper set up those guys are super sharp and I'm sure they can point you in the right direction call Allen or one of the tech guys. You've got a great product and they'll be happy to help. Good luck Sincerely Laz Mesa
MESABALANCING is offline
Old 07-25-2017 | 12:19 PM
Icdedppl isnt running a mercury distributor.
the reason eddie mentioned rotor phasing, is because the boxes remove timing electronically. You can only pull so much timing, before crossfiring in the cap becomes an issue, because the rotor to terminal relationship grows . Especially with a small cap distributor.
Crossfiring while cranking the engine , can certainly cause starter kickback.
Every 4 pulses, equals 1 revolution of the engine. In custom timing mode, you can adjust this. I wanna say max is 12 pulses if i recall. That would be 3 complete revolutions of the emgine before spark ignites.
Old 07-25-2017 | 03:57 PM
I think I just realized the retard feature was turned off on my boxes. I should be ok now. Too much timing at start up I believe was causing the kick back. They have great features with those ignition system s. Stupid me confused on all the dials that control that issue. Otherwise I would have to use kill switches to turn over then light it like the race car guys etc.... Friggin A. Thanks for all the help.
Cary 29 is offline
Old 07-25-2017 | 03:59 PM
Btw I use an MSD zero advance mag p/u dist. So the rotor phase process does not apply
Cary 29 is offline
Old 07-25-2017 | 04:40 PM
SB
What do you have for initial advance as seen with your gun ?
SB is offline
Old 07-25-2017 | 06:38 PM
ROB FREEMAN's Avatar
great mine too .. changed msd distributer ,to a mercury . thought my starter came loose . checked that . I was like wtf .. mark from mer came had issues with computer , never really got the full benefits of the boxes .really bums me out .. now this great ... thanks for the tecknicle knowledge of this issue .. hate to wreck a ring gear ;; sure nasty sounding when she grinds lol
ROB FREEMAN is offline
Old 07-25-2017 | 06:43 PM
I think 20 degrees but the anti stall feature changes it.
Cary 29 is offline
