Daytona Sensors starter issues >
Old 07-27-2017, 08:05 AM
  #31
Received 4,326 Likes on 1,241 Posts
I do everything thru the laptop, the buttons on the side have no options ..
ICDEDPPL is offline
Old 08-07-2017, 09:45 PM
  #32
Just to clarify . unless using a mercury distributor no need to do any rotor sync msd distributor is ok . also the box has built in parameters with the dials and yes you can set a timing retard feature up without using the pc link . if you activate the blue input with a 12 volt source at cranking you could technically customize the amount of timing you wanted removed just by using the dial from 2degrees to 18 degrees. . could set it up multiple ways either using a relay at cranking or off the ignition switch . problem was solved by just enabling the retard function and idle stabilization is still on. engine cranks like a dream . now to hit the 90 mph mark next challenge .
DONZI28ZXSCORPIO is offline
Old 08-07-2017, 10:44 PM
  #33
Good call. I forgot that you can do it that way. I have always used a programmable map setup, that can do start retard based on cranking rpm.
Are you saying that idle stabilization can be used without PC link? I don't see how you could set up the parameters of idle stabilization without PC link?
MILD THUNDER is offline
Old 08-08-2017, 04:25 AM
  #34
SB
Received 3,116 Likes on 1,403 Posts
What problem did you have ?
SB is offline
