-   -   Engine cuts in and out (https://www.offshoreonly.com/forums/general-q/348673-engine-cuts-out.html)
Powerquest230 08-04-2017 09:39 PM
It's something in your batteries/wiring- to confirm start engines (one side and battery at a time) and then turn battery switch off. Carb 502 Mag should keep running with batts off, if you get the same reaction when hitting trim switch, horn, etc I think you rule everything else out. Idle should be fine.
Powerquest230 08-04-2017 09:43 PM
Alternator should run that engine without battery but any switch being activated affects voltage going to ignition and hiccups. Not sure if running electric fuel pumps.
35fountain 08-05-2017 10:32 AM
I shut my batteries off when i'm done for the day. Nothing works with them off. The dash is dead. How could the engine still run?
35fountain 08-05-2017 10:46 AM
To everyone on this thread and to all in the past, I just want to say I really appreciate all the input and information from everyone here at Offshoreonly.com. I am glad to be a member. You have helped me many times in the past and now with my friends boat. Without this site (offshoreonly) and others it could a nightmare finding out these problems. Very much appreciated
Thank you
35fountain
Powerquest230 08-05-2017 11:12 AM
sorry, meant start engine and then switch batteries off- engine should still be running ...
SB 08-05-2017 11:31 AM
Pretty sure that is a big no,no.
sutphen 30 08-05-2017 11:41 AM
purple wire will get no power from the ignition switch(red wire from starter/battery) and engine will shut off.
AllDodge 08-05-2017 11:41 AM
Agree, disconnect the battery from a running motor and your going to need another alternator
sutphen 30 08-05-2017 11:42 AM
Thank you
35fountain
so did you find the problem?
35fountain 08-05-2017 12:30 PM
Not yet but I'm pretty sure we're getting close just wanted to voice my appreciation
