oil temps
Old 10-16-2002 | 08:14 AM
Official OSO boat whore
Well, I have both senders, unfortinately, I didn't have a chance to switch between them. With the oil thermostat, what are you guys seeing for temps after a short cruise? I'm thinking that all the oil is going to the cooler which is why they are so slow to rise.
Cord is offline
Old 10-16-2002 | 01:32 PM
Cignificant's Avatar
Cord, I'm using the Permacool stat along with a large Eddie oil cooler. 6qt oil Pan. I use 15W50 Mobil One. Oil temp sender is in the filter adaptor before the cooler. Water temperature barely registers at 110-120, even with restrictors. Engines are home-built 502 blower motors. When cruising (3500rpm) I see 215 degrees all day long, but it takes a few miles to get there. Hard runs it bumps to 230-235.
Cignificant is offline
Old 10-16-2002 | 03:29 PM
Ok, then I'll get out and run her again. Now if somebody would please turn the heat back on?
Cord is offline
Old 10-16-2002 | 06:05 PM
MACDAD260's Avatar
Charter Member #818
Even with a t-stat it still takes awhile for the engine oil to warm up. The the Perma-cool stat does not close completely, thus allowing much of the oil to go through the cooler as well as back to the engine without being cooled. I was surprised by this when I got mine and looked at it. The installation instructions even mention this. I kinda wonder if it is even worth it to use a t-stat. I have it now so I'll keep it but, I would like to see the difference without it. I'll bet it is not very much.
MACDAD260 is offline
Old 10-17-2002 | 08:24 AM
Based off of my experience, there would be almost no difference.
Cord is offline
Old 10-17-2002 | 08:32 AM
ursus
With the stock merc cooler for a 502 mag 2 x 13 ( 2 x 10) is for the 454 mag) I see oil temps of 240-245ish depending on day with sender in the remote filter block after a long hard run @ 5000, 230ish running fast cruise (4000 rpm) 210ish easy cruise (3200 rpm)
Mr Gadgets
58
12-21-2007 11:54 AM
BobbyB
15
08-08-2006 09:46 AM
BAD-HABIT
9
10-28-2005 07:58 PM
otis311
7
08-23-2004 09:58 PM
Madmax
4
09-16-2002 07:41 AM
