Pre-oiler?
Old 09-14-2017 | 07:18 AM
Default Pre-oiler?
I get these brilliant ideas. And it turns out that everybody either figured it out already or it is stupid after all. You get a 12v scavenge pump. Makes about 30 psi. Feed it off oil cooler line. Put a check ball in block on oil galley fitting. Turn on key. Fire up scavenge pump. Watch oil pressure gauge climb to 30 psi. Start engine. What is wrong with this brilliant idea? Cost about 60 to 100 bucks.
dereknkathy is offline
Old 09-14-2017 | 07:38 AM
One for sale here....
http://www.offshoreonly.com/forums/s...pre-luber.html
ALL_IN! is offline
Old 09-14-2017 | 10:25 AM
I did the same basic thing when I set up my 496's. Many argue it's not necessary but I did it anyway. Our boating season is so short up here in the north I figured it certainly couldn't hurt anything and only help. I had switches for the dash to run pumps and then I never finished the project due to some other implications and started new project with new builds however plan to use same set up with the 548 SC's. Whether or it prolongs bearing life who knows but I personally like the idea of it. I always figured if an oil pump ever failed which is not likely you could always flip the electric pump on.
getrdunn is offline
Old 09-14-2017 | 10:47 AM
IMO, if the oil pump ever failed, it would too late for the pre-lube pump.
Ken
minxguy is offline
Old 09-14-2017 | 10:51 AM
Ken
more than likely. but it might get second engine 10 seconds of run time to hit the dock...
Old 09-14-2017 | 05:50 PM
Hah... I've never had an oil pump fail on any engine so I will just stick with the OT and personally support the installation of but it's just a matter of choice.
getrdunn is offline
Old 09-17-2017 | 12:50 AM
What about a 3 qt Accusump ?
Never tried one on a marine engine though,
but worked great on our race car engines...
chancer540 is offline
Old 09-17-2017 | 01:51 PM
SFOcean's Avatar
Charter Member #394
Canton has a two quart marine version (in blue) with the electric control valve.
Accusump by Canton Racing Products
SFOcean is offline
Old 09-17-2017 | 02:05 PM
BUP
We use this and I am very happy with it. Simple system and less leak points with no added weight in the engine compartment.
Filter - Large Remote Primer Filter Mount - Peterson Fluid Systems
BUP is offline
Old 09-18-2017 | 07:50 AM
That looks like a nice unit - don't think I've seen one before.
ALL_IN! is offline
