500EFI Rebuild/Refresh Questions
Thank you,
Lou
I had my 500 EFIs rebuilt at 526 hours because I waited to long an burnt across the fire ring so it cost me extra for a new block and a new head. So with that your big issue is going to be injectors the Multecs are junk. (check my past posts). You have to replace Valves, rockers, lifters, pistons,rings, bearings,oil pumps etc. Inspect your crank and cam you might be ok. you can get everything that you need to do both motors at Summit all for about $6000. rebuild to stock, retune your computers to new Bosch injectors. Call Jason at MDG Performance in Edgewater Md. He can set you up with the injectors and a program. Mine are just getting to there first full year and it runs great.
