How do these cut outs look
#31
#34
thats likely what I will end up doing...but I have to pull the engine again to gain access. Will report back in the spring as I have no time to do it now. Just wanted to make sure I wasn’t missing something obvious.
#35
Did you straight edge the exterior transom mounting area top, both sides and bottom to see if there is gaps - Merc spec is max 1/16 inch of a gap allowed. And the Inner mounting transom area is 1/8 inch allowed for any gaps using the straight edge method
#36
that is my next task but honestly the assembly at least from the outside sits pretty damn flush. I’ll post pics later. I see no evidence of gaps, etc. looks identical to the other assembly that isn’t leaking.
#37
I'm chasing one too so subscribing to see what you wind up finding. Mine's on the lower RHS of the ring about 2" up from the bottom (when looking aft at the transom wall from the inside of the engine room), bravo 1. Can see it trickling in when dunking on the ramp, then filled the bilge and saw it weeping out. Sealed the ring on the outside with 4200 and still have the issue. Mechanic who was with me says bellows all look good. I'll let you know if I find anything as well, we're in this together.
#39
If you filled the boat up and its weeping out the main seal. I’d say you have the following:
1. Rotten transom that’s caused the main seal to lose squeeze
2. Bad seal (i.e. shrunken, dried out, etc)
3. Corrosion on main plate that’s allowing water in around the seal
i would think adding 4200 would seal it temporarily but think getting to the root cause is paramount. If it were me. I’d pull it apart and see what i have.
Sadly in my case...transom is solid as can be as shown in pics. Zero corrosion on transom assemblies. They are mint. And the main seal is brand new 2 months old. Not sure what i have going on.
#40
its def not top steering pin. Top steering pin leak is the easiest to diagnose in my opinion. Any traces of water on the top ledge of the assembly around the steering arm and 9/10 it’s the steering pin seal. Mine is dry as a bone.
