Which top mount starter to buy >
Old 11-04-2017 | 07:20 AM
Default Which top mount starter to buy
Have no experience with CCW starters/or top mount starters for BBC boat engines, as have narrow stringers and top mount 2-bolt bellhousing so though might as well use it.
Only used tilton CW starters in cars
Need reliable, good cracking starter and if possible to save some weight
What's eveyone running:
1. API marine 10MT delco
2. Delco Remy MT14
3. Delco gear reduction style
4. Denso gear reduction style
brett fiddes is offline
Old 11-04-2017 | 07:43 PM
#3 worked well on 540's w/ blowers.still going as of today,about 10yrs later.
sutphen 30 is offline
Old 11-05-2017 | 05:11 AM
what you mean might as well use it. do you have top mount starters now? and if so, which ones? if you have bottom mounts and want to switch you need different flywheels or to have ring gear installed on the other side of the flywheel.
dereknkathy is offline
Old 11-05-2017 | 07:07 AM
Have no starters for the marine engine now
stringers are only 22" wide so its seems a little tight to fit the starter in between
Therefore need to buy new a starter
Have the top mount bellhousing thought I would run them
have a few flywheels here a mixture of alum and steel auto and marine, although haven't paid to much attention to whether they would ift
So need to change the ring gear on flywheel
can you run a flex plate with this setup and use a spacer as saw Rex marine has 1/2" spacer plate which looks like it may do same job
Big Block Chevy Flywheel Spacer, 1/2" thickfor use with Flexplate and Reverse Rotation Starters: Automotive Performance Products, Boat & Marine Parts & Hardware
Thanks for the infor. actually setting up engine/transmission/drive mounting plates in boat so just trying to think ahead
cheers
Brett
Old 11-05-2017 | 09:53 AM
bck's Avatar
bck
Charter Member#568
You can tell by looking at the flywheel if the ring gear is mounted toward the front or rear. I had a machine shop change mine. I found that not all machine shops could do it.
Straight bottoms and flat decks
bck is offline
Old 11-05-2017 | 05:12 PM
Rookie's Avatar
You can change the ring gear with a propane torch, a 2 2x4 blocks, a punch and a hammer.
Set the flywheel on the 2x4 blocks, heat up the ring gear and lightly tap around the gear and it will fall off.
Make sure you grind off the spot welds if someone spotted it to the flywheel.
I've done it about a dozen times
Rookie is offline
Old 11-05-2017 | 05:32 PM
bck's Avatar
bck
Charter Member#568
If i remember correctly my flywheel had a groove machined into it. The ring gear had a slight protrusion on the underside that rode in that groove to ensure it didn't move. This groove needed to be remachined into the correct place place on the flywheel to relocate the ring gear. Not all machine shops had a lathe that could accommodate the flywheel. Thats my story and im sticking to it. As far as what brand starter, I found a local shop that rebuilt starters with quality parts not the chinese stuff they are filled with when new.
bck is offline
Old 11-05-2017 | 06:34 PM
14 apache's Avatar
Delco Remy MT14 I do believe these have the most HP
14 apache is offline
Old 11-05-2017 | 06:52 PM
Guys
Thanks for the infor,
I'll need to go through the steel and aluminium flywheels to see what I have and can use
For the starter selection I looked at the weights of the starters and looks like option 1&2 are 23 pounds, and option 3&4 are 10lbs in weight. So I only have small 21' boat so was trying to see whether I could keep the weight down a little. Not sure what the gearing is on the Delco reduction gear starter (#3) but Denso looks to be 3-4/1
As far as flywheels go, do most people normally use the standard nodular iron flywheel, steel or aluminium. The boat is being used for play boat in harbour/open bay, running turbo 502ci or 560ci N/A BBC, through Daytona crash gearbox, casale parallel drive (so can be geared over/or under drive),
I suppose with aluminium when you take your foot out of the gas you lose the rotating inertia, I was planning on running 14" flywheel
any help much appreciated
Old 11-05-2017 | 07:08 PM
14 apache's Avatar
Originally Posted by brett fiddes
Guys
Your not going to run a shaft whirl away in the boat can be dangerous if your at good speed and something fails. I have run aluminum flywheel in my v-drive with SBC worked great. What boat do you have??
