head gasket selection
#34
575sci, 500EFI, 525EFI, all came with the old school gaskets at some point. That has now been changed as I stated earlier, and if you walk into a merc dealer, and order a replacement gasket for any of those engines, you get a Cometic MLS gasket with a Mercury Part # on it. That part # is 27-811546A04 . All of those engines were known to have head gasket sealing issues over time before the MLS stuff.
The 700SCI, 600SCI , new 565EFI , all come with the MLS gasket.
#35
Teagues thoughts.
Forced induction high performance marine engines are hard on cylinder head gaskets. Fight back and prevent torched blocks and cylinder heads with the right marine head gaskets from Cometic and Felpro, available for all generations and bores of Big Block Chevrolet. Teague Custom Marine uses Cometic or Felpro multilayer cylinder head gaskets on all engines over 700 horsepower, and Felpro Marine high performance cylinder head gaskets on less than 700 horsepower naturally aspirated engines.
https://teaguecustommarine.com/em001...tf017lp5as8f61
#36
#37
So in the end I went with felpro MLS gaskets...a buddy that has built several race engines agrees with everything that was said on here and said to run the MLS for peace of mind...I appreciate all your guys' help!!
Stewart
Stewart
#39
ARP bolts...gonna be a bit before she actually goes back together but picked up boxes of parts last night so I have everything minus pistons at this point...gaskets, rods, bearings, timing chain, oil pump, etc....ready to start building when the work schedule allows..will post a build thread and hopefully pics when I start making progress...
Thunder....do you really think this will be 700 hp?? I was shooting for 6-650 so anything over that is a bonus!! lol
Stewart
Stewart
#40
Teagues thoughts.
also,seems like over time the felpro marine like to weep water out the side of the block,cometics seem to cure that problem.just did heads and gaskets on a whipple 502 and they were leaking bad at 100hrs.will see next summer how things are holding up.these motors get turned up to 5800rpm on a regular basis,36 specte cat.
food for thought.
