Merc 1000 SC cam specs and Straub >
Old 11-09-2017 | 08:06 PM
SB
Just in time.
Going to be 12*F here in the AM.
SB is offline
Old 11-09-2017 | 08:30 PM
Ya were chilling in the north for sure. This weather sucks monkey balls. Anyway ya let's just stay on the subject which is pretty much covered and I do appreciate the post regardless.
getrdunn is offline
Old 11-09-2017 | 09:25 PM
Aaaaannnd it’s officially winter.
Baja Rooster is offline
Old 11-11-2017 | 07:02 AM
Did you already buy the 900 cams?
indysupra is offline
Old 11-11-2017 | 12:19 PM
yes I did but not really what my head guy wanted for optimum performance with what he's done with the heads.
getrdunn is offline
Old 11-11-2017 | 05:16 PM
what does he want?what hp/tq are you shooting for?
sutphen 30 is offline
Old 11-12-2017 | 02:20 PM
Looking for 900 plus. Static comp is 8.2 and probably 6-7 pds boost. i thought the cam would be close to right on considering merc had to spend some R&D time but jim would like to see a little more lift and less duration. I understsnd what his angle is but.... He has a great grind for his NA 565 TR that peaks hp right at 6k. 236/242 I believe. I think his concern is with higher duration cam port velocity gets lazy.
getrdunn is offline
Old 11-12-2017 | 02:51 PM
bck's Avatar
bck
Charter Member#568
So how much lift is he suggesting with that duration? Hate to see you have to sell them on Facebook.
Straight bottoms and flat decks
bck is offline
Old 11-12-2017 | 03:14 PM
They are older tech and are harder on valvetrain than some of the newer grinds.
Old 11-12-2017 | 07:36 PM
evidently there was a couple different grinds that went into 900's according to norm at cfs (competition fuel system). The earlier ones had some pretty steep ramps and very quick to come off and back on the seat.
New springs and lifters every 50-75 hrs but if I'm not mistaking that hasn't changed even today. No real biggie as that's about every 2 seasons Btwn work and weather yet if there was other choices without sacrificing power and easier on valvetrain I'd consider.
getrdunn is offline
