Oil Pressure Questions >
Old 10-18-2002 | 08:02 AM
CelticPride
Default Oil Pressure Questions
Here is the scenario:
When engines are cold...at idle..pressure is pegged at 40 psi. run out the intracoastal out into the ocean and run the boat for a while at 3600 to 3800 and pressure slowly drops just below 40 psi at these rpm's..come down off of plane to idle and pressure drops really low and will stay there for a while and then come back up.
Over time, maybe 15 to 20 hours of use the pressure will not get as high as 40..maybe 35. this is probably due to viscosity breakdown.
Engines have about 350 hrs on them and run excellent.
Do I have a problem of just wasting server space? lol
Old 10-18-2002 | 11:38 AM
blue thunder's Avatar
I think you are fine as long as there is no engine noise when the pressure reads low.
BT
blue thunder is offline
Old 10-18-2002 | 11:45 AM
CelticPride
Actually, there is a noise. Its like a clanking noise..it doesn't last long. It's like the noise when you tap on the water pump pully with a screw driver or something.
Old 10-18-2002 | 03:32 PM
Sounds like the bearings in the bottom end are probably going out.
Griff is offline
Old 10-18-2002 | 05:04 PM
Oil temps?
BadDog is offline
Old 10-18-2002 | 07:32 PM
MACDAD260's Avatar
Charter Member #818
Sounds like the oil is getting too hot and thinning out excessively. Probably hurting the oil. That is why the pressure drops even lower after a few hours. What engine are you running and what is your WOT rpm? Depending on your setup you may be lugging the engine and causing it to overheat the oil. If your WOT rpm is near 4600 to 5000 rpm you probably just need more oil cooling capacity.
MACDAD260 is offline
Old 10-18-2002 | 08:19 PM
Celtic Pride ..take an oil sample...that tells a lot. What oil and weight are you running???
By the way ..Bill Laimbeer Rules!!!!
powerqrudy is offline
GoCiggie31
7
08-19-2007 06:07 PM
dockrocker
17
08-05-2005 09:30 PM
mleslie951
27
11-08-2004 08:03 PM
FlyFast
13
05-10-2004 11:39 PM
