525 sc gurus >
525 sc gurus
525 sc gurus
Old 12-07-2017 | 11:21 AM
BBYSTWY's Avatar
Default 525 sc gurus
In the process of collecting parts for my 525 sc rebuild and ARP main studs are on the list...I haven't opened mine up yet due to my work schedule so bear with me...
Does anyone know if a 97 525 sc is a 2 bolt or 4 bolt main??
thanks
BBYSTWY is offline
Old 12-07-2017 | 12:26 PM
TomFTM's Avatar
4 bolt. I think I have two sets of new arp main studs, I bought them a while ago , and never used them. Will let u know .
TomFTM is offline
Old 12-07-2017 | 12:28 PM
BBYSTWY's Avatar
sweet thanks!!
BBYSTWY is offline
Old 12-07-2017 | 01:22 PM
TomFTM's Avatar
i just looked , I have 2 sets of new arp main bolts not studs... You do realize if you use main studs you have to line bore the mains.
TomFTM is offline
Old 12-07-2017 | 01:29 PM
BBYSTWY's Avatar
I did not know that...so if I use the bolts is it as simple as just rebolting the mains back on after replacing bearings and balancing rotating assembly??
would you want to sell a set of the bolts??
BBYSTWY is offline
Old 12-07-2017 | 01:31 PM
BBYSTWY's Avatar
Should be around the 650 hp range...256 blower with chiller, forged pistons/rods, dart iron eagle heads, roller cam/rockers....would the bolts be sufficient??
thanks
BBYSTWY is offline
Old 12-08-2017 | 09:55 PM
Originally Posted by bbystwy
should be around the 650 hp range...256 blower with chiller, forged pistons/rods, dart iron eagle heads, roller cam/rockers....would the bolts be sufficient??
yes.
mike tkach is offline
Old 12-09-2017 | 08:32 AM
I see no reason to run main studs, if you feel iffy on the bolts ARP bolts then, you will want to replace the rod bolts and size the rods for sure..
ezstriper is offline
Old 12-10-2017 | 02:01 PM
TomFTM's Avatar
Yes , I wil let u know.
TomFTM is offline
Old 12-12-2017 | 08:55 AM
BBYSTWY's Avatar
sounds good thanks!!
BBYSTWY is offline
