Superchargers and outdrives >
Old 01-19-2018 | 07:37 AM
F-2 Speedy's Avatar
Originally Posted by payuppsucker
I've been running 700 HP through a pair of bravos for about 500 hrs. The drives are original circa 1992. Over 1100 total hours on the drives, never opened up. I'm easy on and easy off and it I air it out it's not intentional. Don't get me wrong, I use every bit of power I have and I beat on it when someone makes me do so. It's all up to how you work the throttles.
Come on granny.................and second Im shocked 800hp is breaking a bravo....
F-2 Speedy is online now
Old 01-19-2018 | 07:48 AM
Sydwayz's Avatar
Forum Regulator
Sydwayz is offline
Old 01-19-2018 | 07:53 AM
That "granny" talk will end when I get to TR!!!!
payuppsucker is offline
Old 01-19-2018 | 08:31 AM
Originally Posted by TwoKs
I am planning on around the 6 grand mark also. 540 going in a Activator 27. Was planning on procharging but dont want to do the blow through carb thing so decided to go roots carbed.
Nothing looks better than a carbed roots blower motor IMHO. Well maybe a giant PSI carbed blower motor but that’s it. Good choice sir!
SecondWind is offline
Old 01-19-2018 | 10:31 AM
When I had my blower boat I was always easy on the sticks getting on plane. This is a lot of load on your drives and where you are most likely to break them. I never had any issues but I also had Teague Platinum XRs as well.
racinfast002 is offline
Old 01-19-2018 | 10:58 AM
Plus the concept of being good on the throttles, can vary. It' easy to work the throttles when you're jumping over a random wake from a cruiser that you encounter a couple times a day while boating. Not so much when you're on the ocean or great lakes, and your on/off the throttles every 4 seconds for 30 plus miles at a crack. High x dimensions and rough water is the number 1 drive killer in my opinion.
MILD THUNDER is offline
Old 01-19-2018 | 11:59 AM
If you are going to run big power, and currently have bravo's, saye your money to convert them to IMCO SCX uppers. To save some money, you can run an IMCO SC lower. Here is the deal with Bravo's.
There is a lot of smoke and mirror sales guys out there. Special shafts, coated gears, better bearings, it goes on and on. NONE of it, is going to do much if anything, OTHER than drain your wallet. The clutch shaft is a major weak spot in the bravo drive, and there is nothing you're going to do to improve that. Steel towers will help keep everything lined up, BUT it won't fix the issues. Mr. Gadgets in my opinion, has the best tower upgrade for the money, so be wise when spending your money, but it has its limits as to what it will do.
What I would suggest is keep your eye open for a nice set of IMCO SCX drives. They pop up from time to time, and they will handle the power you will be making. I've seen them as low as $7k ea, which isn't a whole lot more than a rebuilt bravo XR. Speaking of XR's, 200 hours on an XR, and its most likely due for new gears, at $1600 plus labor. Again, if you're planning on new power, start saving for new drives, and don't waste a penny on making your bravos "better".
endeavour32 is offline
Old 01-19-2018 | 12:23 PM
I agree on the scx. Except I think I would opt for the scx lower as well. My buddy Joe had scx uppers, with sc lowers, on his 42 fountain with a pair of 1000s. He sold the boat with very low hours, like maybe 10-20 hours on the new engines. I think the sc lowers were as fresh as well, and they new owner took the lowers apart and they were shot. Both lower gear sets that is.
I think the reason the #3,4,5,6,8 drives handled power well, was because they had two gearsets in the lower. Each driven by it's own vertical shaft. Putting all that torque thru one gearset that has to be small enough to fit inside the bullet, is just not strong enough for today's engine. This is also why the power handling capability of a speedmaster drive, can be immensely reduced if set up by someone who isn' familiar with them. If each lower gearset assembly isn't setup so that power gets split equally to both sides, they will fail prematurely.
Old 01-19-2018 | 12:29 PM
Great point about high x-dimension and rough water. Throw high horsepower mills into that equation and parts start to break.
Old 01-19-2018 | 12:48 PM
I agree, but to keep cost down, the SC lower will work. The SCX lower is stronger, but for that bigger gear set, the lower is bigger, and I've had guys tell me they lost 8 mph with the SCX lower. It's all a trade off, personally, I'd take the speed loss, for added durability. I know IMCO has a new lower that addressed the speed loss issue, but I doubt you would find one used.
