525SC Pig in a poke *HELP PLEASE*
You do realize this is like asking a 15 year old boy about the cake recipe that Kroger used when his mom bought his birthday cake there.... Then logging on to Betty Crooker .com and asking if said cake tastes good....
Yeah..theres eggs and flour in the cake....
Either offer what your willing to lose and or recoup selling parts or find someone reputeable to do a compression test, leak down, oil analysis etc....
CAke is good, 525sc's are good...either can be screwed up or go stale...
Im hungry now....
Im hungry now....
Ya now that I went back and re read the OT there seems to be a lot of unsurities from owner. Many I don't knows and can't remembers it seems. We all have a little brain fog from time to time but this seems a little extreme. Ignorance can leave the door wide open for a can of worms as well as get one off the hook.
Never know could get lucky but more I think about it I would go into it looking at complete refresh at the very least. Engine rebuilt properly with assm lube etc and rotated on occasion doesn't bother me sitting for some time. Even then depending on where it was stored condensation can take its toll on things also.
Thanks for all the help.
I put a camera down the cylinders, standard L2453 dished pistons but one had 4-5 small circle dents so I'm thinking that was detonation? So it looks like the machine shop honed the Cylinders and re-used the original pistons, not sure about the rings. My guess would be a hand hone so it'd have to come apart just to spec everything, even if it was done right, check the cam they installed, crank. Heads and valves don't look like they touched them, still have carbon on them.
Blower pulley has a slight forward/backward rock no in/out or side to side play, bearings roll smooth.
Motor is missing sea water pump, and maybe fuel pump, flame arrestor, air filter, 525sc cap, any idea who might have some spare 525 pieces sitting around?
Motor was stored dry, no oil, and not sure if they used assembly lube or not ��
Cylinder are pretty clean but there is a little surface rust on the piston crowns/edges.
What should I budget to go through the motor and spec it, if everything turns out to be ok, and if I do the labor work myself? (I'll have to hire out machine work). I understand I'll have to replace and parts that are not right or machined incorrectly.
Does it have the original dominator on it? Those usually ran pig fat. Also ck the size of the pulleys to make sure their stock. Detonation coulda been from some bad fuel also. I have a feeling the last repair was just what was necessary to get back up and running. Just figure on a tear down and refresh and worse case might need new pistons, along with normal refresh. Heads... new valves, possibly springs, surfaced, etc. Not a huge deal but I'd still figure 3-5k for parts and machine work and you assemble. Just depends. It's difficult to go into it assuming minimal work. If it wear me I'd tear it down and drop rotating assembly, heads and block off at machine shop or run it until she's deep six.
Just not sure whats in your tool box but you can do a lot yourself also. Pull pan ck bearings, crank. Spring pressures and on. Pretty basic stuff and not real time consuming but could save you some money in the long run if you decide to chance it. Slight in and out blower pulley play not uncommon but may be time for refresh on that also. You get a chance rotate it and see how it feels and looks with carb off.
The biggest problem with a quick "go thru it" is you end up with the "might as wells" Im going thru this right now. THe 525sc is like 7.1 cr. So I might as well get new pistons and raise the compression to are 8.5... So by the time I have the heads completely redone, I might as well just buy some aftermarket alum heads, ... you know with more compression, I might as well give it a little more cam, and I might as well make it a roller and add some decent lifters... Well Im going to be making more power, so I might as well give the oil some love and get a 12 qt pan, new cooler, and HV pump and a nice billet filter setup with bigger lines.... and why take chances with this, so we will add a bigger fuel pump Then there is the antique ignition system, might as well replace that...
It all adds up, but then again so does the horsepower level....
So take what you think its going to cost and triple it.
Your right phragle. Without a doubt. Probably 90% of us here or more would wanna do exactly what you said. That's the part that makes us who we are as well as broke and sometimes remorse and other times a big smile. Just depends on how disposable income is.
I do agree on the might as well do's but I just want a good sold running motor that'll do 500Hrs. I don't need to upgrade drives or do a 100 on the river, so though it'll be tough to hold myself back it'll be what's best in the end.
I give you credit but just make sure you do everything by the book and to marine specs. I wish you were closer I'd have you bring it up to our shop and give you a hand. Just remember when in doubt ask. There is no dumb question especially if you don't or haven't done much of this before. Although I seriously like your willingness to learn and want to do but I have to ask if you have a reputable shop nearby you can trust. I'd certainly pull the heads and pull the pan for starters. That would be a good start but just find a place to have your heads gone through including replacing valves even if they ck out fine. List goes on and on but family guy is on right now. Lol... you'll be ok. Just do everything right the first time.
