hydraulic steering VERY stiff at idle
I'm running Marine Machine twin ram with a Char-Lynn helm and a 500 EFI. At idle, the wheel is VERY stiff. It literally takes both hands to turn. Only when I bring the RPM's up to 1200-1300 RPM and above, it eases out and acts normal. It makes it difficult when docking and trailering. It almost sounds like not enough pressure at idle. Marine Machine thinks my power steering pump may be defective or damaged. Any ideas??
Sounds like either a bad pump or do you have underdrive (smaller) crank pulleys? I know that when I put underdrive pulleys on my boat ( cuz I was waiting for the others to come back from being painted) that my steering at idle was really hard.
Jon
Jon
Put your best foot forward!
I'm running the original pulleys that come on a 500 EFI. I thought about swapping the pulley, but I don't think anyone is making any for a serpentine set-up - are they? I wouldn't think I would have to change it, being that other 500EFI owners can run the same set-up with no problems. I guess that only leaves the steering pump.....
