Running 496 on a stand
you need to hook the battery - to the block and the battery + to the starter, which will provide +12vdc on the pin where the large red wire is, this will connect to the center post of the switch, then the switched +12 will return on the smaller red wire thats connected through the plug to the starter relay, your ecm, alternator, ect should be powered off the other wires connected to the + starter terminal where the battery connects.
Oh I have a 10 pin plug and fuel injection,I need to run power to the ECU this then controls the eight coils.
Thanks for the offer of coming over and starting my engine,cant yet I am still in the middle of a major rebuild.
Thanks for your help
......pin 5 is coil...........mine are carb on EFI
