-   -   Swapping from a 502 to a 496 HO (https://www.offshoreonly.com/forums/general-q/35265-swapping-502-496-ho.html)
mats 10-21-2002 01:58 PM
Swapping from a single 1996 502 MPI with silent choice exhaust to a 2003 496 HO. Will it bolt right in?Enginemounts? Exhaust ports? Wishbone?
Mark in So. MD 10-21-2002 02:32 PM
Man thats a mighty big price tag for 10hp and fresh water cooled. Does the 502 have problems because a 96 is not very old?
mats 10-22-2002 11:05 AM
Yes, the 502 has major problems, bad compression, consumes a quart of oil an hour and it does not give more than maybe 350 hp. Basically I have given up on it.
CAP071 10-22-2002 07:03 PM
HMMMM might be a good core to start on a Hi-Po rebuild?
bobl 10-22-2002 08:56 PM
mats, why not have a good shop go through that 502 and rebuild and blueprint it. A little head work and a cam change will give you 500 horsepower for a whole lot less than a new 496.
Bob
CigDaze 10-23-2002 07:06 AM
Warranty might be a consideration as well as stock reliability and the cloded cooling...But $4$, the 502 is more effective.
OPIE272 10-23-2002 05:18 PM
If you are looking to give away your old 502 oil leaking, low compression, tired 502 and worthless for trade in, let me know I might be interested.
CAP071 10-23-2002 05:42 PM
I need a coffee table so if you want I may be able to pick the junker up. I wouldn't even charge you for disposal :D
Mark in So. MD 10-23-2002 08:14 PM
Nice of you to help him out CAP:D :D :D
CAP071 10-23-2002 08:17 PM
Anything for a fellow OSO member. I measured and YES it will fit in my living room! :D
