-   -   Holley HP EFI Data Logs (https://www.offshoreonly.com/forums/general-q/352676-holley-hp-efi-data-logs.html)
Rage 03-06-2018 11:40 AM
Does any one have Holley HP EFI data logs from BBC in boat running with knock sensor(s)?
launchpad475 03-06-2018 08:04 PM
I could probably dig some up, what are you looking for?
indysupra 03-06-2018 08:53 PM
I do.
Rage 03-07-2018 07:20 AM
I am in particular looking for any data log records when going from idle to on plane and/or throttle down from WOT or high speed down to idle. At this point any in boat data logs with knock levels record of a similar BBC type engine on water running would be of interest. I am interested in what may be the differences or similarities of other in boat engine knock level characteristics.
Rage 03-08-2018 06:09 AM
FYI, All I want is any and all raw recorded Holley HP EFI data logs I can get from in boat running of BBC with knock sensor(s). Not asking for these data logs to be prescreened for content that I am interested in. I will take all I can get.
indysupra 03-09-2018 06:59 PM
I will fire up my laptop I use for tuning but I probably only have some logs while I’m on it. Are you having an issue or wondering if a certain knock value is normal.
Rage 03-10-2018 05:02 PM
Its the knock vs false knock issue. My engine (in the boat) is very noisy requiring sensitivity setting down to 35% just to get by. Then 100% knock levels show up where they should not be. I need to see what a different BBC engine/boat knock level looks like for comparison along with all the other data logged parameters.
Rage 03-12-2018 11:30 AM
https://cimg9.ibsrv.net/gimg/www.off...d5d7ce077e.png
Example of what I am talking about.
Rage 03-25-2018 09:24 AM
Does anyone have Holley HPI data logs of BBC running in a boat with knock sensors?
ACrooks69 03-25-2018 10:54 AM
Are you running your rockers on the loose side? Maybe when the RPMs come down enough after having the lifters pumped up, the decreased oil pressure is allowing some momentary clatter and you are picking that up.
