Help with IAC motor on 575sci >
Old 03-25-2018 | 02:24 PM
Just found this from Walker (printed in 2012) and says on page 3, that 575sci s/n 0L306696-0M950526 use Walker p/n 215-1026,but still unable to find the A03
http://www.walkerproducts.com/wp-con...-actuators.pdf
AllDodge is offline
Old 03-25-2018 | 06:48 PM
Thanks for all your help, I will make some calls tomorrow. Just wanted to place my order asap but wanted to make sure I knew what I was doing. I do appreciate your help.
radrogerb123 is offline
Old 03-26-2018 | 07:45 AM
I'd call Eddie Young - he will likely advise you of Merc vs aftermarket usage/application possibilities.
ALL_IN! is offline
Old 03-26-2018 | 10:42 AM
I have one in my hand for the engines that use an IAC for each throttle body.
GM# 17113099
AC Delco# 217-429
snapmorgan is offline
Old 03-26-2018 | 10:44 AM
I have no use for this one anymore, no longer have 575's. PM me your address and I will send it to you if you want
Old 03-26-2018 | 10:53 AM
I always carried a spare. Funny how these would last 200K miles in a car, but won't last 100hrs in a boat
Old 03-26-2018 | 11:06 AM
What are the symptoms of a bad IAC? My motor loads up at idle and also keeps revving when the throttle is closed for a few seconds after high rpm operation.
Old Navy is offline
Old 03-26-2018 | 11:22 AM
High idle or won't idle. Sounds like you may need an IAC and injectors. The injectors are prone to leaking and making it load up at idle
