Where should AFR readings be for MPI 509
Did a run out, stopped a while and run back. The RPM stays close to the one on the helm until about 4K, then according to the computer read out it stops, and the helm keeps climbing until around 5100 or so. Just got the files and still don't know how to go through the stuff, but unable to find the files other then by opening scanner Pro. Thought I would upload for folks that are use to seeing things and could provide some advise, but no go. Don't understand why I can see them to load but not as actual file.
I'm using an administrator account, but only difference is I just change it to admin to see if I could find the file
What cylinder heads? Timing is conservative by a few degree's up top in my opinion. Had an engine a few weeks ago that I added 3 degree's up top and picked up 100 rpm. Even the HP500 has 34* timing. How much timing is added for the stall saver? Adding a few more degrees of initial at idle or extra in the stall saver may clean up the transom some.
I aggree with Smitty about giving it as much fuel as it needs at idle. With a B3 it might need the fuel to run and shift without stalling.
They are Merc/GM stock cast iron heads with a bit of porting.
Don't know what a "stall saver" is, but assume its for smoother operation between pulse widths transissions
If this motor was in a lighter boat it may not have this issue, as I need to be turning at least 3400 rpm to stay on plane, likes it best at 3600. Turning standard B3-26 pitch, 2.0 drive, XR upper
