Another Cam recommendation >
Old 06-01-2018 | 09:52 AM
Default Another Cam recommendation
Not very happy with the performance of this reground cam so I am looking for something to push my single 30 ft Advantage better than what I have. I currently have a Crane 741 in my Summit Racing cart to buy but before I pull the trigger I wanted to see if someone had something better to suggest. I have read a ton of threads on here on cams and the 741 is very popular it seems. My motor is a 555 with just over 10:1 compression and has some massaged 088 heads with a single plane intake. My main concern is reversion as I have Imco Thumper exhaust. Would love to have headers but just not in the cards for right now. I also have a step nose Gen VI cam.
Tahoe540 is offline
Old 06-01-2018 | 09:58 AM
The Comp Cams 525EFI cam has same specs as the 741 but with 114 LSA
Baja Rooster is offline
Old 06-01-2018 | 10:07 AM
SB
Don't you boat at a bunch of elevation tahoe540 ?
SB is offline
Old 06-01-2018 | 10:10 AM
Yes I mainly boat on Lake Tahoe at 6200 ft elevation. Have to stay N/A due to no room for blower pulleys. Trying to make the best of what I have to work with.
Tahoe540 is offline
Old 06-01-2018 | 10:12 AM
F-2 Speedy's Avatar
the note on the card recommends installed @ 6* advanced, is that where you put it ?
F-2 Speedy is online now
Old 06-01-2018 | 10:30 AM
I did install it @6* advanced when it was a 548 and got some very minimal signs of reversion. Since I rebuilt it this winter I installed it only 2 degrees advanced and am seeing reversion plus not very happy with the performance even though it dyno'd well as a 548 at 6* advance.
Tahoe540 is offline
Old 06-01-2018 | 10:34 AM
What are you not happy with about current cam? I'm not in love with the current cam specs. Single pattern cam with poor flowing 088 exhaust ports and restrictive exhaust. 6-10 degrees more exhaust duration than intake will help your setup. IMO......741 cam is too small for a 10:1 555ci. It should help with reversion though.
Ryan00TJ is offline
Old 06-01-2018 | 10:39 AM
Well, we did mention turbo. What’s the current cam specs? Edit: Nevermind. The cam card pic finally loaded.
Old 06-01-2018 | 10:47 AM
I’m no engine builder, but everything seems kinda small for the size engine that you’ve got. Getting power at elevation is tough as you’ve got to pack in tons of air to get any power and your set up is on the mild side for even a 502. My guess is that you’ll need better heads and a bigger cam to get enough air for the power that you want.
Old 06-01-2018 | 11:04 AM
This is the only cam I have had for this boat and engine so just looking to see what might be a better choice with minimal reversion with my crappy exhaust. I also feel the 741 is too small and that is why I am asking for suggestions. May just end up getting a custom ground done as that has been my best outcome on past motors.
Tahoe540 is offline
