Sticky valve guide >
Sticky valve guide
Sticky valve guide
Old 06-18-2018 | 12:26 PM
Default Sticky valve guide
I’m assembling my heads and one exhaust valve is sticky. It’s fairly free within the range of lift but otherwise needs to be pushed through pretty stiffly while all of the other valves will fall through on their own weight. All of the other exhaust valves fit the same way and I’ve polished them up on the drill press and 2000 grit wet paper. Buy a reamer for just that one valve? 11/32” stems.
Baja Rooster is offline
Old 06-19-2018 | 07:31 PM
tripps's Avatar
Default Valve guide
Bring it to a engine builder that have a hone that fits it common problem from galling
tripps is offline
Old 06-19-2018 | 09:28 PM
you sure theres not a burr near or around the groove for the locks.
sutphen 30 is online now
Old 06-21-2018 | 11:39 AM
The valves mic out at .3405 and this guide is .3410. All of the other guides are at .3420. It’s amazing this thing didn’t punch through the piston. The inside of the guide is tougher than the rest as I jiggle the mic in it so I’m guessing it may have tried to seize at some point.
