replacement block for 525SC >
Old 06-21-2018 | 08:46 PM
Default replacement block for 525SC
I broke a valve and cracked my block. Which blocks and heads are compatible to replace with? I am not trying to make more power I just want a reliable replacement for my damaged block and head. Thanks
Riverrattralph is offline
Old 06-21-2018 | 08:48 PM
What year or gen?
getrdunn is offline
Old 06-21-2018 | 08:54 PM
1994 gen 5
Old 06-21-2018 | 09:59 PM
PM sick stinger. I would bet he would be able to help you out.
getrdunn is offline
Old 06-22-2018 | 01:15 AM
You don't really anything compatible. You can use any Generation 454 with 4 bolt mains and a forged crank.
If you're getting a new block and heads, there are better ways to go than stock that won't cost any or at least not much more and make more hp at the same time.
Griff is offline
Old 06-22-2018 | 04:51 AM
BBYSTWY's Avatar
Agree with griff...do yourself a favor and buy a 502 block...you can probably find a useable one pretty reasonable and bolt all your S/C stuff on it...my block was good when I just did my rebuild so it wasn't cost effective for me to go bigger at the time but I def left some horsepower on the table by not going to a 502....since you have to buy one anyway go 502 at least
BBYSTWY is offline
Old 06-22-2018 | 07:18 AM
So do I need forged pistons and forged crank? I was looking at crate motors and not sure if they would hold up. So you are saying all my accessories would bolt right on to a 502? Would I need to change the carb or ignition?
Old 06-22-2018 | 07:24 AM
BBYSTWY's Avatar
All accessories will bolt up...at most a jet change and a little tuning from the carb but I don't see why the dominator wouldn't work...ignition should work just fine as well....don't quote me on this but I believe any marine 502 will have a forged crank at a minimum...if I were you I would buy a running 502 from someone here and freshen it up with a roller cam....you are gonna be getting to the end of the limits on what your blower can do and you will most likely make less boost on a gauge but more power at the end of the day with a 502 based setup...in my opinion I wouldn't go bigger than a 502 unless you plan on upgrading the blower to a bigger unit
Stewart
BBYSTWY is offline
Old 06-22-2018 | 07:50 AM
F-2 Speedy's Avatar
the 502 mag will have forged internals if it hasn't been messed with
F-2 Speedy is offline
Old 06-22-2018 | 09:25 AM
Would I need standard rotation or left hand?
