500EFI alarm >
500EFI alarm
500EFI alarm
Old 07-05-2018 | 11:07 PM
BUP
rpms when shifting into gear is ?
Rpms in N is ??
both engines doing the exact same thing here ? both showing the same rpms as well ?
Never stalls in N and you can throttle up and back down to idle rpm without it ever stalling in N using throttle only ?
stock OEM set up here ?
SCX drive or just gear lube bottles --- so something on the engine is not stock at all to warrrant an SCX drives if applicable . What the set up in detailed here.
How new is the IMCO drive bottles install ?
this happens on the water hose also ?
Stock ignition ?
whats the voltage readings when engines stalls ? and what is the voltage when you shift into gear ? what is voltage reading in N - still want to know what rpms are ?
BUP is offline
Old 07-06-2018 | 06:58 AM
splashandburn's Avatar
Originally Posted by SB
most efi set up's if oil psi falls below a certain # the fuel pump will be shut off. this is only bypassed during cranking.
Rpms in N is ??
Stock ignition ?
rpms are 850 in neutral and 750 in gear.
splashandburn is offline
Old 07-06-2018 | 07:05 AM
Rpms in N is ??
Stock ignition ?
Both engines show the same rpm and only having an issue with one motor.
Once I get passed the shift I have no issues throttling up or back down. Doesn't happen every time and only happens at idle.
non stock set up - 540's with Prochargers.
I've been running this motor set up with SCX drives for the past 3 seasons.
Havent run it on the hose as boats in the water.
Running MSD boxes.
Havent checked voltage yet - planning to look at it again today
Old 07-06-2018 | 08:21 AM
Sounds like bad ground somewhere...
1MOSES1 is offline
Old 07-06-2018 | 10:22 AM
BUP
Running MSD boxes.
Thats a whole different world for testing and trying to figure out whats wrong NOT BEING STOCK AT ALL. Nothing is stock period. Dart throwing for the fix. I did asked what was voltage readings so monitor it
is this an CARB or EFI set up ? Alot of info needs to be known to even come close for a fix.
BUP is offline
Old 07-07-2018 | 07:18 AM
Looks like the issue is the throttle position sensor. Anyone know if this is a standard GM part that might be available at a local auto parts store?
Old 07-07-2018 | 10:15 AM
BUP
I was trying to be funny with is carb or efi question - attempted humor by far ----- anyways
So you scanned the engine ?
Try to mach up with an AC delco part number - I forgot what that part number is.
BUP is offline
Old 07-07-2018 | 11:04 AM
yes I was wondering if there was an AC Delco part #.
Old 07-07-2018 | 12:11 PM
SB
I really don't know (have notg replaced a Merc 500EFI tps) but it sure as heck looks like this:
ACDelco 213-894 GM Original Equipment Throttle Position Sensor
by ACDelco
Link: http://a.co/8tjywfj
SB is offline
Old 07-07-2018 | 12:12 PM
SB
her is the factory look up:
https://www.marineengine.com/newpart...pnum=MER849903
SB is offline
