High Idle - Regardless of Carb Adjustment >
Old 08-19-2018, 04:36 PM
Originally Posted by SB
I asked the same thing above.He said cable is adjusted properly but he did not say exactly if he re-adjusted it or not.
The cable had enough slack after the adjustment. I adjusted it again to just to give a shot and no change.
I checked for vvacuum leaks and the starboard side was missing a cap on the back nipple. Weird, considering that is the side that acts the most normal. Would I need to readjust the timing on that motor now with the nipple plugged? Would that effect all-in timing?
AWOL is offline
Old 08-20-2018, 12:37 PM
I would ck to see where timing is when idling high...maybe advance hanging up ?
ezstriper is offline
Old 08-23-2018, 03:19 PM
I went and tinkered with the boat. Capped the vacuum lined coming off the starboard motor and had to adjust the throttle screw to bring rpm up to normal. All is fine there. No hung up/high idle.
Port side, although the cable has enough slack, the linkage is getting slightly caught up after I use the throttles to open it up. Any recommendations on lubricating it or anything I can do to have it operate smoother? It catches at the very end and only takes a slight nudge of the hand and it settles where it should. With more slack in the line, I get a different rpm reading than the starboard side motor with the throttles in the same position.
It just seems like a slightly stuck port throttle cable is my issue.
AWOL is offline
