Originally Posted by IGetWet
(Post 4658329)
Is the plan to still get the motor dynoed? Take it from someone who really wishes they dynoed their motor when they had the chance, have it dynoed!
Originally Posted by getrdunn
(Post 4658351)
Where does the inner SS pipe end in reference to the weld on those CMI's? Be nice if it was back far enough to have wideband o2 sensors. No need for dyno. |
Finally made it out with the new engine and all went well! Still shy of two hours run time (probably an hour of that on the hose) so no wot runs but from cruising at 3500rpms it launches hard and keeps pulling where the previous engine fizzled out a bit. Pretty stoked with it. The Holley Sniper works like a charm and I don’t miss fiddling with jets the slightest. Having a small issue setting the IAC to the correct parameters but it runs great. Idle 13.5 cruise 12.8 WOT 12.5 Verifying AFRs with a wideband on the odd bank and the two sides are within .2 of each other, as near as I can tell. Cold oil oil pressure at cold was a bit high for my taste at 75psi but eventually got back to 60 and 20 at idle after a moderately brisk run. 30w Brad Penn break in oil. |
| All times are GMT -5. The time now is 04:31 AM. |
