Bbc blower motor help! >
Old 10-13-2018 | 04:36 PM
GPM
The center pod of the Daytona is raised higher than the Warlock or the American Offshore. 1000 HP and a -2 should get you close to 120 mph.
GPM is offline
Old 10-14-2018 | 12:05 AM
Originally Posted by Daytona25
So I should be ok with the xr and bmax lower then mike??
it,s not bullet proof but way better than a standard bravo.
mike tkach is offline
Old 10-14-2018 | 12:07 AM
Also do you recall what drive ratio, prop, and rpm you were runnin on the American offshore??
it,s ben a while but i think 1.35 gear,30 or 32 pitch bravo four blade prop and around 6400 rpm.
Old 10-14-2018 | 12:17 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Originally Posted by mike tkach
im not sure but a oso member [the deep] has a 25 warlock with a 509 i specked for him,your boat should run almost the same as his.maybe he will chime in on this one.i had a 26 american offshere with a little more hp and it did 106.it was almost 900 hp.i destroyed a standard brave in short order and replaced it with an xr,it was still on the boat a few years later when i sold the boat.
The Warlock hasn't seen the water yet with the new power Mike . I am making progress on it though , finally .
the deep is offline
Old 10-14-2018 | 08:22 AM
That’s a lot, 660hp currently I’m turning a 1.5 ratio and 30p bravo 4 blade 5600....I didn’t think 850 would let me step up to a 1.36 ratio and keep a 30p or go up to 32p the extra power must really wake these boats up!?
Daytona25 is offline
Old 11-05-2018 | 05:20 PM
So I found a good deal on a new 871 which for my 509 is sized appropriate, is there a difference in performance from a billet blower shop blower to a Weiand?? Also with a 509 and 871 would I benefit to move up to dominator carbs over the 750-850 carbs I have now??
Old 11-05-2018 | 08:30 PM
Tinkerer's Avatar
Daytona - I have a 2001 26 Daytona and running 650 HP and -2 imco lower the boat ran 94 MPH best 90 to 91 anytime. That was with a 1:5 ratio and a 28 pitch Bravo 4 blade.
Today I am running a 598 NA at 800+ HP at 112 MPH anytime. that is with a 1:34 ratio -3 IMCO lower and a labbed 28 Bravo 4 blade at 6100 RPM. My propshaft is 2 inches above the lowest point on the hull.
Tinkerer is offline
Old 11-05-2018 | 11:17 PM
the blower shop will be the better blower,dominator carbs are nice but not necessary,a pair of 4150 1050 carbs would be my pick but 850s would work.
Old 11-06-2018 | 06:38 AM
That seems like your prop is really shallow, I have a -2 lower I’m about 2” lower than rub rail at top of drive and still 2”-2.5” below the bottom, I’d think at 2” above the bottom the boat would just cavitate and not plane out?? Mike I’m leaning towards a billet blower shop blower I was assuming they would make the best power out of them all and they look a lot better imo was thinking the 3 circuit dominators would have the best tuning capability but the 4150 1050 would allow me to keep my flame arrestor and stuff I already have!
Old 01-21-2019 | 08:14 PM
So I found my dyno sheets and original paperwork for my current motor also decided to keep it and ad the 871 billet blower shop blower with blower shop intercooler do these sheets give us any valuable information about current cam ect??
