Merlin 345 Grumpy Jenkins flow numbers... Stock and ported?? >
Old 10-14-2018 | 09:37 AM
What will you be into your current heads for once rebuilt and what will you be replacing?
hogie roll is offline
Old 10-15-2018 | 05:00 AM
Full Force's Avatar
Not sure yet, but savings of buying new castings, I get my work done fairly cheap as it's a friend also.
Full Force is offline
Old 10-15-2018 | 06:26 AM
I do not know your combo, but 345's are large for normal size(468-509) boat engines, unless I'm off on this opening up the ports a bit more not going to give you much at the RPM's we usually see ?
ezstriper is offline
Old 10-15-2018 | 08:36 AM
Full Force's Avatar
I am 548CI, they are still a tad large to me but these engines were also done 20 years ago before all the good heads we have now... opening up ports and making better flow don’t always happen at same time, you can gain flow without hogging them.
Old 10-15-2018 | 06:28 PM
An old thread. You may have seen but thought I'd post anyway.
merlin grumpy jenkin cast heads
getrdunn is offline
Old 10-16-2018 | 05:21 AM
Full Force's Avatar
Saw that, Didn't see numbers.. ugh
Old 10-16-2018 | 11:00 AM
Old 10-16-2018 | 12:21 PM
Panther's Avatar
Frank's Marine Service
How old are the heads? The decks on those heads were notorious for caving in on the combustion chambers and getting holes. Had it happen to me two times on my engines many many years ago. If the heads need seats and guides anyway it might not be worth the fuss to fix them and then have them ported. But I guess you'll find out soon enough!
Panther is offline
Old 10-16-2018 | 12:27 PM
Full Force's Avatar
Pretty sure 1999 era when emgines were redone..
Old 10-16-2018 | 08:58 PM
They have a 26* valve angle. Most aftermarket performance heads have a 24* valve angle.
Heres some flow numbers from my head guy. All flowed on same bench, same fixture, etc
MILD THUNDER is offline
